![]() | Home > Technical > Steering guard fitment, 300tdi & puma |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2362 ![]() ![]() ![]() |
It will fit Christian.
HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6199 ![]() ![]() ![]() |
As Mo says. It'll fit. BUT.... it's a royal PITA to fit to the puma's as you can't get your arm down inside the engine bay to get a nut on the fixing bolts.
I helped a forum member fit a Mantec ali guard to his puma 110, I have the same guard on my Td5. Mine was about 1000x easier to fit. |
Christian1402 Member Since: 17 Feb 2016 Location: Cumbria Posts: 214 ![]() ![]() ![]() |
Thanks for the replies guys, much appreciated
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 ![]() ![]() ![]() |
Purchased a steering guard from Paddocks for my Puma. No problem fitting, just removed a couple of bolts from the front chassis rails (accessed from underneath) and replaced with those supplied in the kit.
