Home > Td5 > Original Tyre Change Kit or What Should I Have Realistically
simon67
England 2004 Defender 90 Td5 HT Rutland Red
Had Lusty since Apr 15 and as per normal she came with no tools for changing a wheel over
Putting tyre change into search gives me 500 posts on what wheels to have
Two options
Original - what should I have complete with part numbers to keep her original, jack, brace etc
Reality - as much LR stuff is pants, what works in the real world
Answers on a postcard please
Many thanks
Post #529109 4th May 2016 6:34pm
Fatboy Slim
Wales
Good 1/2" power bar and 27mm socket from machine Mart/halfords etc
Discovery or P38 bottle jack from the breakers Thumbs Up
Post #529121 4th May 2016 7:46pm
ickle
^^^^ As above^^^^ Razz
Post #529139 4th May 2016 8:28pm
Bps
As above with a decent piece of wood to put jack on just in case you are on soft ground and a wheel chock
Had my halfords breaker bar for 10 years with no problems. Also doubles up as a jack handle if needed for the bottle jack
Post #529174 4th May 2016 10:02pm
apachecow
1999 Defender 110 Td5 CSW Rutland Red
I've just ordered one of these for mine:
http://www.ebay.co.uk/itm/261281033753
Post #529181 4th May 2016 10:21pm
jimbob7
+3,To repeat you do want a quality 6 sided socket.Cheapo ones crack.Halfords and Machine mart are worth looking at.
Gedore,my favourite Very Happy
https://www.gedoretools.co.uk/nc-sockets-1...results=11 Pov.spec,ftw. 2006, 110,TD5.
Post #529255 5th May 2016 10:04am
jimbob7
Looks good!! Pov.spec,ftw. 2006, 110,TD5.
Post #529257 5th May 2016 10:07am
simon67
wheel chock
Why a wheel chock, having never used one on any car why are Def's different?
How many do you need, when would you use it, might be a daft question so apologies
Post #529275 5th May 2016 10:50am
Rashers
I would recommend a breakdown membership like Green Flag, AA, RAC etc. Trying to change an offside wheel on the side of a busy road is life limiting (especially if you live in Norfolk with the driving round here). Joking apart, it's not a fun place to be and the breakdown people will have a big van with flashing lights to put in between you and the flat tyre.
Post #529297 5th May 2016 12:25pm
jimbob7
simon67 wrote:
wheel chock
When you apply the handbrake inna Defender ONLY one wheel (out of 4) is "braked".So a physical wheel chock is very good..Watch any number of hgv's sliding backwards down a hill IN THE SNOW coz they only applied the handbrake.They suddenly stop completely coz the footbrake is applied (ALL WHEELS). Pov.spec,ftw. 2006, 110,TD5.
Post #529306 5th May 2016 1:38pm
miker
Proper 1/2" breaker bar, 600mm is fine.
27mm socket (I use an impact socket because I tend to gun them off)
28mm socket (Alloy wheel nuts, the stainless caps corrode and swell. Check you can get a 27mm over them before you need it! Half of mine I have to use an 1-1/8" Socket I had lying around that fitted.
Bottle jack, designed for lifting on axles, not just a flat topped one.
Wheel chock is good, if not 100% necessary. Always put in diff lock too when jacking.
Sealey tools are pretty good. Picked up a bar for £13 and socket set for £30. Individual sockets probably around £5. I've not killed the sealey stuff yet and I use my tools a lot.
Post #529313 5th May 2016 2:11pm
