![]() | Home > Td5 > Original Tyre Change Kit or What Should I Have Realistically |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Good 1/2" power bar and 27mm socket from machine Mart/halfords etc
Discovery or P38 bottle jack from the breakers ![]() |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
^^^^ As above^^^^
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 847 ![]() ![]() |
As above with a decent piece of wood to put jack on just in case you are on soft ground and a wheel chock
Had my halfords breaker bar for 10 years with no problems. Also doubles up as a jack handle if needed for the bottle jack |
apachecow Member Since: 12 Apr 2016 Location: Yorkshire Dales Posts: 59 ![]() ![]() |
I've just ordered one of these for mine:
http://www.ebay.co.uk/itm/261281033753 |
+3,To repeat you do want a quality 6 sided socket.Cheapo ones crack.Halfords and Machine mart are worth looking at. Gedore,my favourite ![]() https://www.gedoretools.co.uk/nc-sockets-1...results=11 Pov.spec,ftw. 2006, 110,TD5. Last edited by jimbob7 on 5th May 2016 10:08am. Edited 1 time in total |
Looks good!! Pov.spec,ftw. 2006, 110,TD5. |
simon67 Member Since: 18 Jun 2015 Location: west sussex Posts: 569 ![]() ![]() ![]() |
wheel chock
Why a wheel chock, having never used one on any car why are Def's different? How many do you need, when would you use it, might be a daft question so apologies |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3633 ![]() ![]() ![]() |
I would recommend a breakdown membership like Green Flag, AA, RAC etc. Trying to change an offside wheel on the side of a busy road is life limiting (especially if you live in Norfolk with the driving round here). Joking apart, it's not a fun place to be and the breakdown people will have a big van with flashing lights to put in between you and the flat tyre.
When you apply the handbrake inna Defender ONLY one wheel (out of 4) is "braked".So a physical wheel chock is very good..Watch any number of hgv's sliding backwards down a hill IN THE SNOW coz they only applied the handbrake.They suddenly stop completely coz the footbrake is applied (ALL WHEELS). Pov.spec,ftw. 2006, 110,TD5. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
Proper 1/2" breaker bar, 600mm is fine.
27mm socket (I use an impact socket because I tend to gun them off) 28mm socket (Alloy wheel nuts, the stainless caps corrode and swell. Check you can get a 27mm over them before you need it! Half of mine I have to use an 1-1/8" Socket I had lying around that fitted. Bottle jack, designed for lifting on axles, not just a flat topped one. Wheel chock is good, if not 100% necessary. Always put in diff lock too when jacking. Sealey tools are pretty good. Picked up a bar for £13 and socket set for £30. Individual sockets probably around £5. I've not killed the sealey stuff yet and I use my tools a lot. |
