Home > Td5 > Is a 1999 Td5 OBD2 compliant?
Loz2286
If not, what system does it run? 1999 Td5 110 CSW
1961 Series 2 88 LPG
Post #514479 15th Mar 2016 10:31am
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
The TD5 has a ODB socket, but it's not ODBII compatible;
See thread;
http://www.defender2.net/forum/topic20403.html
I bought a Nanocom for mine and it does what I need it to.
Post #514504 15th Mar 2016 12:09pm
4RF RDS
No it is not, Nanocom or another less expensive scanner like iCarsoft 930 will do what you need. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #514527 15th Mar 2016 1:38pm
MadTom
If you are looking for good working diag for TD5, than you can choose Nanocom or Hawkeye. These work OK. 930 is not good enough. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #514549 15th Mar 2016 2:53pm
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
I use the X431, it can do some basic jobs, I use it to scan the system and deleted the ABS code!
its work but not as good as Nanocom, but its cheap! Mr. Green
Post #526566 25th Apr 2016 5:03am
