Home > Technical > Electrics and diagnostics 1998 TD5
johnnyd
Hi All
Just a few questions about electrics etc, the connector under the middle front seat, is that to connect diagnostics too?
Also i fitted a raptor-engineering housing yesterday and found a clear connector in the center dash with 3 or 4 wires going to it not connected to anything, its not the cigarette lighter or window washer as i have those still, anyone any ideas?
Also if i want some monitoring in the truck, do i look at something like a madman ems2 or does a nanocom do the same and more ?
Thanks
JD
PS this is in the Defender TD5 1998 2008 TDCi 2.4 XS CSW
Post #235112 13th May 2013 10:47am
Re: Electrics and diagnostics 1998 TD5
johnnyd wrote:
Hi All
Yes, it's the OBD socket.
Not sure. Could be the loom for a heated windscreen. What colours are the wires?
Not familiar with the Madman, but I've got one of the older Nanocoms and it tells you all you could reasonably need to know about the TD5. Darren
Post #235117 13th May 2013 11:06am
davew
Re Madman vs Nanocom etc...
The madman is a monitoring system, the Nanocom is a diagnostics system. You would't normally leave a Nanocom plugged in all the time and it won't warn you when something goes out of it's normal operating range. You can use a Nanocom to get more detailed information about the ECUs and change their settings.
The Madman is permanently connected and you can set low and high alarm levels for everything it's monitoring so it can draw your attention to a problem as soon as it happens. You can't change ECU settings or interrogate the ECU with a Madman.
Ideally you'd have both but the madman is the only one of the two that could be described as a monitoring system. http://www.yorkshireoffroadclub.net/
Post #235208 13th May 2013 5:58pm
Nanocom you can run in "instrument mode" which shows you batt voltage, water temp, RPM and boost pressure, but doesn't trigger any alarms if they go out of limits.
Post #235230 13th May 2013 6:37pm
