![]() | Home > Td5 > Is a 1999 Td5 OBD2 compliant? |
Loz2286 Member Since: 31 Aug 2015 Location: High Wycombe Posts: 121 ![]() ![]() |
If not, what system does it run? 1999 Td5 110 CSW
1961 Series 2 88 LPG |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 ![]() ![]() ![]() |
The TD5 has a ODB socket, but it's not ODBII compatible;
See thread; http://www.defender2.net/forum/topic20403.html I bought a Nanocom for mine and it does what I need it to. |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 682 ![]() ![]() ![]() |
If you are looking for good working diag for TD5, than you can choose Nanocom or Hawkeye. These work OK. 930 is not good enough. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 ![]() ![]() ![]() |
I use the X431, it can do some basic jobs, I use it to scan the system and deleted the ABS code!
its work but not as good as Nanocom, but its cheap! ![]() |
