![]() | Home > Maintenance & Modifications > Heated seat wiring / FCX kit |
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 ![]() ![]() ![]() |
I've got myself an fcx wiring kit to wire up the standard half leather heated seats on my td5 90. One query though, are the standard defender xs seats heated base and backs? Both the bases and backs seem to have a connector each coming out of them (at least there are 2 plugs per side, 1 with a yellow band one plain black) however the wiring kit I have only has 1 reciprocal plug per side unless I'm missing something?
Basically do I have heated seat bases and backs and can I wire up both using the fcx kit? ![]() Cheers! |
Presuming your seats are standard and haven't been messed about with, there should be two leads coming from the backrest.
The lead with the stripe plugs in to the squab and the other plugs in to our kit This gives you heat to base and backrest |
Awesome cheers! Makes sense now
All wired up. Very easy to do with the instructions on the fcx site
![]() Now need some cold weather to give them a good go! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20979 ![]() ![]() |
I've got if too but with Waeco pads.
Really good. ![]() |
Try emailing FCX direct
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 942 ![]() ![]() ![]() |
Thanks, I will do, I just stumbled across this old thread whilst researching
Definitely worthwhile, very pleased with mine exorcising in this weather. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
