Home > Maintenance & Modifications > Heated seat wiring / FCX kit
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
I've got myself an fcx wiring kit to wire up the standard half leather heated seats on my td5 90. One query though, are the standard defender xs seats heated base and backs? Both the bases and backs seem to have a connector each coming out of them (at least there are 2 plugs per side, 1 with a yellow band one plain black) however the wiring kit I have only has 1 reciprocal plug per side unless I'm missing something?
Basically do I have heated seat bases and backs and can I wire up both using the fcx kit? Laughing
Cheers!
Post #485428 25th Dec 2015 10:12pm
Presuming your seats are standard and haven't been messed about with, there should be two leads coming from the backrest.
The lead with the stripe plugs in to the squab and the other plugs in to our kit
This gives you heat to base and backrest
Post #485468 26th Dec 2015 8:51am
Freypal
Awesome cheers! Makes sense now Smile
Post #485478 26th Dec 2015 9:38am
Thumbs Up Thank you for the business Bow down
Post #485479 26th Dec 2015 9:53am
Freypal
All wired up. Very easy to do with the instructions on the fcx site Thumbs Up 2 hours tops.
Now need some cold weather to give them a good go!
Post #487324 31st Dec 2015 7:17pm
I've got if too but with Waeco pads.
Really good. Thumbs Up
Post #487360 31st Dec 2015 8:23pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Hi,
Old thread resurrection here but looking at re trimming and new foams on my 04 td5 non heated seats in the new year at some point.
I am thinking about adding heating to them and want a factory finish so looking at the td5 fcx loom kit but what heater pads would I need to buy to plug and and play? I see Exmoor trim do an oem heater pad kit with oem plugs so would this match up with the td5 fcx kit?
Thanks
Mike
Post #875694 1st Jan 2021 6:41pm
Try emailing FCX direct
Post #875714 1st Jan 2021 7:39pm
Mike c
Thanks, I will do, I just stumbled across this old thread whilst researching Thumbs Up
Post #875719 1st Jan 2021 8:06pm
Definitely worthwhile, very pleased with mine exorcising in this weather. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #875723 1st Jan 2021 8:18pm
