Home > Technical > Viscous fan, how to remove?
Page 2 of 2 <12
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
pj2106 wrote:
I just brought a set of spammers from flat dog to do mine 😀
I can see the version for the TD5/V8 on flat dog's website but not the one for the Puma. Too bad it looked reasonably priced Rolling Eyes
It's not the same tool, I reckon it's different size and the one for the puma uses pins that plug into the pulley.
Post #440078 24th Jul 2015 10:50am
o4dn
So I eventually ordered a pulley holder that I had to cut as it was too thick to fit in between the fan and the pulley.
Did the job just fine!
Post #443168 4th Aug 2015 8:27pm
Okan
Switzerland 2009 Defender 110 Puma 2.4 SW Stornoway Grey
Hi all
I have to remove the viscous fan on my 2.4 PUMA too. Do you have some links to order the two special tools to do it easily?
Best regards
Post #580915 27th Nov 2016 10:00pm
o4dn
If you can afford the price of the original tool, I would definitely recommend http://www.dingocroft.co.uk to order the LR tool (ref. 303-1334)
http://www.dingocroft.co.uk/cgi-bin/sh0000...303_2d1334 “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #580922 27th Nov 2016 10:12pm
dorsetsmith
snap
or two pieces 25mm flat steel bar with 6mm holes both ends use two 6mm bolts and nuts and bolt the other too gather now you can hold the hub with 6mm bolts in it
Post #580924 27th Nov 2016 10:15pm
ickle
If you have a sds drill with chisel only function, a very quick zap with that and its instantly undone - no where near as brutal as it sounds, mine resisted a home made special tool and spanner, a hammer and chisel & I tried the sds in desperation, worked superbly with hardly a mark on the nut!
Keith
Post #580927 27th Nov 2016 10:25pm
Okan
Thanks all
I will place an order on dingocroft. I allready broken my fan shroud. It will spend me some time and maybe money if I directl take the correct tool for doing this:-D
regards
Post #580957 27th Nov 2016 11:08pm
Okan
Hi!
I was waiting for my tools and I tried only with a 36 spanner and hammer. It worked fine! Only few trying and it worked!
Maybe sometimes it could be impossible if it's too much rust but some WD-40 and it should work for those doesn't have the special tool.
Best regards
Post #582739 4th Dec 2016 10:11pm
Page 2 of 2 <12
