![]() | Home > Technical > Viscous fan, how to remove? |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 589 ![]() ![]() ![]() |
So I eventually ordered a pulley holder that I had to cut as it was too thick to fit in between the fan and the pulley.
![]() Click image to enlarge ![]() Click image to enlarge Did the job just fine! |
Okan Member Since: 17 Oct 2016 Location: Geneva Posts: 138 ![]() ![]() ![]() |
Hi all
I have to remove the viscous fan on my 2.4 PUMA too. Do you have some links to order the two special tools to do it easily? Best regards |
If you can afford the price of the original tool, I would definitely recommend http://www.dingocroft.co.uk to order the LR tool (ref. 303-1334)
http://www.dingocroft.co.uk/cgi-bin/sh0000...303_2d1334 “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
![]() Click image to enlarge snap or two pieces 25mm flat steel bar with 6mm holes both ends use two 6mm bolts and nuts and bolt the other too gather now you can hold the hub with 6mm bolts in it ![]() Click image to enlarge Last edited by dorsetsmith on 27th Nov 2016 10:43pm. Edited 2 times in total |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1858 ![]() ![]() ![]() |
If you have a sds drill with chisel only function, a very quick zap with that and its instantly undone - no where near as brutal as it sounds, mine resisted a home made special tool and spanner, a hammer and chisel & I tried the sds in desperation, worked superbly with hardly a mark on the nut!
Keith |
Thanks all
I will place an order on dingocroft. I allready broken my fan shroud. It will spend me some time and maybe money if I directl take the correct tool for doing this:-D regards |
Hi!
I was waiting for my tools and I tried only with a 36 spanner and hammer. It worked fine! Only few trying and it worked! Maybe sometimes it could be impossible if it's too much rust but some WD-40 and it should work for those doesn't have the special tool. Best regards |
