![]() | Home > Technical > Viscous fan, how to remove? |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
I got a cheap tool out of halfords.
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 601 ![]() ![]() ![]() |
Yeah, but ... Halford is a tad far for me
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
If you have no tool to do it with, you can give the nut a very sharp tap with a chisel, or punch on the very edge.
They usually spin off ok ![]() Wanted, Forward Control Anything considered. |
Yep long chesil and sharp tap normally does it ok
Oh sorry didn't see your flag. Like the others said it can be done with a sharpe whack with a chisel.
No worries! Actually, if you had a reference or even a picture (or maybe a link on Halfords' website), maybe I could try to find it around here, who knows
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6041 ![]() ![]() ![]() |
One a bit like?
http://www.ebay.co.uk/itm/Land-Rover-36mm-...3ceb0d5d72 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Nope, that one I have, it's the pulley holding spanner that I'm missing
Currently considering ordering this:
http://www.lasertools.co.uk/item.aspx?cat=1153&item=7774 Would that do the job? |
Ahh this one then, 6 pic down
http://www.dingocroft.co.uk/acatalog/Tools2002-p3.html 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Yes, exactly, but ... a cheaper alternative
Thanks all for the replies
![]() I'll keep the chisel as a last option (I'd rather avoid damage), meanwhile I've ordered a couple of adjustable pulley holding tools from the interweb and I'll see how it goes. Or else I'll pay a visit to LR, they must have the right tool for the job ![]() I'll post the results if that can help others. |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
I just brought a set of spammers from flat dog to do mine 😀 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
A while ago I needed on in a hurry, so I made my own -
![]() Click image to enlarge It's just a length of 50mm wide x 6mm thick strip steel I had kicking around in the garage, used a 44mm hole saw for the cut-out and 12mm drill for the holes to slip over the pulley bolts, works a treat ![]() I later added the smaller cut-out at the other end (40mm) for the Disco 3 fan. |
