![]() | Home > Technical > Puma grill removal and surround |
| Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112
Grockle
I take out mine to install the radiator protection net. It is quite easy (30 min to take out app). If I remember well there is 2 screws at both sides of the grille frame and another 4 or 5 at the top. That allosw to take out the frame an the grille is attached with the fasteners Unfortunately the "fir tree" fastener are quite weak, so if you like to do it, first get at least 6 or 8. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266
thanks Ed,I've ordered some fir trees just in case
| Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 617
Anyone know what size the fir tree clips are?
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Best thing is to remove the grille in it's entirety and then push the fir tree clips out from the rear.
| Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226
Another spectacular resurrection!
