Home > Technical > Puma grill removal and surround
Grockle
as above how does it come off and the best way to remove thr 'fir tree' fastners 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #36021 12th Jul 2010 11:58am
Eduardo
Grockle
I take out mine to install the radiator protection net. It is quite easy (30 min to take out app).
If I remember well there is 2 screws at both sides of the grille frame and another 4 or 5 at the top. That allosw to take out the frame an the grille is attached with the fasteners
Unfortunately the "fir tree" fastener are quite weak, so if you like to do it, first get at least 6 or 8.
Cheers Eduardo
Post #36053 12th Jul 2010 6:34pm
Grockle
thanks Ed,I've ordered some fir trees just in case Thumbs Up 2.4 90 XS
Post #36100 13th Jul 2010 8:13am
Jim_Bean
Anyone know what size the fir tree clips are?
Post #285677 27th Nov 2013 2:47pm
K9F
Best thing is to remove the grille in it's entirety and then push the fir tree clips out from the rear. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #285734 27th Nov 2013 6:47pm
Green Machine
Another spectacular resurrection! Laughing 2005 Td5 | 90 Station Wagon | Tonga Green
Post #285738 27th Nov 2013 6:55pm
