![]() | Home > Technical > Puma grill removal and surround |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Grockle
I take out mine to install the radiator protection net. It is quite easy (30 min to take out app). If I remember well there is 2 screws at both sides of the grille frame and another 4 or 5 at the top. That allosw to take out the frame an the grille is attached with the fasteners Unfortunately the "fir tree" fastener are quite weak, so if you like to do it, first get at least 6 or 8. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
thanks Ed,I've ordered some fir trees just in case
![]() 1968 1/32 scale Britains 109 Pick up. |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 617 ![]() ![]() ![]() |
Anyone know what size the fir tree clips are?
Best thing is to remove the grille in it's entirety and then push the fir tree clips out from the rear.
![]() Treat every day as if it is your last....one day you will be right!! |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
Another spectacular resurrection!
