Home > Maintenance & Modifications > What is your best and worst modification?
Page 7 of 7 <1234567
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
I've done a few tweaks to my 110 over the last few years of ownership.
Best mods - Lighting LED headlights and rear work lights. I can now see when going forwards and backwards. Gas strut on the rear door, it now stays open all by itself.
Worst - Nothing. Perhaps I've been lucky but everything has been good so far. However, I've not fitted too much extra stuff.
Post #1066593 29th Apr 2025 10:22am
orled
BlackVue dash cam front & rear
Post #1071596 16th Jul 2025 7:43pm
gilarion
Land Rover Defender Mirror Head Adapter Kit
This adapter fits all standard Defender mirrors used on all 90/110/130 Models from 1983 onwards. (If you have this style fitted to your Series model, then they will also work)
Designed and manufactured by us in the UK to tackle the issue of not being able to see past your Caravan / Trailer / Horsebox with the standard mirrors, even if you have XD extended mirror arms set up on maximum reach!
Once fitted, these will allow you to rotate the mirror head through 90 degrees to the horizontal position, increasing the field of vision behind you and past the item you're towing.
These adapters are brilliant, and no more fiddling with extended mirrors. They fit onto your standard mirror arms and take ten minutes to fit. They are fit and forget.
https://www.designdevelopmenteng.co.uk/sho...p389433941
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #1072778 4th Aug 2025 3:42pm
