![]() | Home > Maintenance & Modifications > What is your best and worst modification? |
orled Member Since: 02 May 2013 Location: NWest Posts: 30 ![]() |
BlackVue dash cam front & rear
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5140 ![]() ![]() ![]() |
This adapter fits all standard Defender mirrors used on all 90/110/130 Models from 1983 onwards. (If you have this style fitted to your Series model, then they will also work)
Designed and manufactured by us in the UK to tackle the issue of not being able to see past your Caravan / Trailer / Horsebox with the standard mirrors, even if you have XD extended mirror arms set up on maximum reach! Once fitted, these will allow you to rotate the mirror head through 90 degrees to the horizontal position, increasing the field of vision behind you and past the item you're towing. These adapters are brilliant, and no more fiddling with extended mirrors. They fit onto your standard mirror arms and take ten minutes to fit. They are fit and forget. https://www.designdevelopmenteng.co.uk/sho...p389433941 ![]() Click image to enlarge ![]() Click image to enlarge For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
