![]() | Home > Puma (Tdci) > Engine goes cold on tickover |
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 ![]() |
I think it's normal. Mine is the same, isn't this why they sell rad muffs? 110 Hardtop
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
ditto also think normal, not burning much fuel at tick over so not generating much heat hence why a lot of diesels have aux heaters DEFENDER 90 TDCI XS,
If you have the heater blowing on hot then you would be surprised how much cooling effect on engine it will have .
diesels dont make much heat when ticking over , could leave one ticking over all day after cold start and bet it would never get near running temp |
ParabolicSwivel Member Since: 13 Nov 2013 Location: Hertfordshire Posts: 42 ![]() |
Haha, blimey, that's reassuring. Will never worry about overheating then - it wasn't even all that cold.
Will invest in a blanket and a few cable ties then. ![]() Surprisingly, the dealer didn't even suggest that 'they all do that'. Thanks for the advice chaps! |
Yes I pick my lad up from college some nights and when it's cold weather with the heater on on tick over my ultraguage shows around 40 degrees Celsius, not the 78 degrees or so normal tootling temperature
get a webasto fitted
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2789 ![]() ![]() |
is it just me that doesn't get rad muffs?
Surely when its not warm, theres no water moving through the radiator anyway.... thats what the thermostat is for!! So how would a rad muff help? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Inclined to agree, if the thermostat is OK why would you need one DEFENDER 90 TDCI XS,
the engine block/hoses etc will act like a rad in cold weather , stopping cold air being pushed in to engine bay will help with warm times how cold it has to be to help i don't know |
I had the same on my 300tdi Disco while waiting on the ferry. Heating on and wind from ahead heating stayed warm but temp gauge went down. Roel
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
Pick the revs up a bit to 1200-1500 it will warm up again
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 ![]() |
Mine appears to be super critical of the water level, if it drops too far then it doesn't appear to circulate much hot water through the heater at idle. If it's up to level or slightly over there's no problem and maintains hot even at tick over
