Home > Puma (Tdci) > Engine goes cold on tickover
ParabolicSwivel
Hi all
Hoping for some inspiration from you guys, as the main dealer has given up on me. And my warranty is about to expire anyway.
I've found over the winter (courtesy of some long-running major roadworks near Nottingham) that if I sit stationary for more than 5 or 10 minutes the temp gauge starts to droop. After more than 10 mins the gauge is at the bottom of the white section and the heater feels cooler than normal (but not cold).
Once I start off again driving normally the temperature gradually picks up again as usual.
The thermostat seems ok in general as the temp stays right in the middle in normal driving.
I wonder if it might be the viscous fan coupling? How can I test that?
Is it easy to convert the Puma to an electric fan instead?
Thanks!
Post #400696 20th Feb 2015 9:28pm
pob1968
I think it's normal. Mine is the same, isn't this why they sell rad muffs? 110 Hardtop
Post #400698 20th Feb 2015 9:31pm
LR90XS2011
ditto also think normal, not burning much fuel at tick over so not generating much heat hence why a lot of diesels have aux heaters DEFENDER 90 TDCI XS,
Post #400701 20th Feb 2015 9:38pm
munch90
If you have the heater blowing on hot then you would be surprised how much cooling effect on engine it will have .
diesels dont make much heat when ticking over , could leave one ticking over all day after cold start and bet it would never get near running temp
Post #400703 20th Feb 2015 9:42pm
ParabolicSwivel
Haha, blimey, that's reassuring. Will never worry about overheating then - it wasn't even all that cold.
Will invest in a blanket and a few cable ties then. Very Happy
Surprisingly, the dealer didn't even suggest that 'they all do that'.
Thanks for the advice chaps!
Post #400704 20th Feb 2015 9:42pm
pob1968
Yes I pick my lad up from college some nights and when it's cold weather with the heater on on tick over my ultraguage shows around 40 degrees Celsius, not the 78 degrees or so normal tootling temperature Smile 110 Hardtop
Post #400708 20th Feb 2015 9:54pm
T1G UP
get a webasto fitted
Post #400722 20th Feb 2015 10:44pm
Cheshire110
is it just me that doesn't get rad muffs?
Surely when its not warm, theres no water moving through the radiator anyway.... thats what the thermostat is for!!
So how would a rad muff help? Cheers, David
Post #400739 20th Feb 2015 11:46pm
LR90XS2011
Inclined to agree, if the thermostat is OK why would you need one DEFENDER 90 TDCI XS,
Post #400764 21st Feb 2015 7:31am
munch90
the engine block/hoses etc will act like a rad in cold weather , stopping cold air being pushed in to engine bay will help with warm times
how cold it has to be to help i don't know
Post #400783 21st Feb 2015 9:57am
roel
I had the same on my 300tdi Disco while waiting on the ferry. Heating on and wind from ahead heating stayed warm but temp gauge went down. Roel
2003 90 Td5 (2009-now)
Post #400785 21st Feb 2015 10:11am
AndrewS
Pick the revs up a bit to 1200-1500 it will warm up again Thumbs Up 130's have feeling's as well you know Smile
Post #400787 21st Feb 2015 10:24am
Rickydodah
Mine appears to be super critical of the water level, if it drops too far then it doesn't appear to circulate much hot water through the heater at idle. If it's up to level or slightly over there's no problem and maintains hot even at tick over Confused I started with nothing and still have most of it left!
Post #400959 21st Feb 2015 8:57pm
