Home > Td5 > oil pressure warning light flickering |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
I would first try replacing the oil pressure switch,
And go from there 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
9th Feb 2015 8:50pm |
could pull the wire off the switch
if it stops flickering then its the switch if it keeps flickering then its the wiring when does it flicker on tick over or all the time ? Last edited by munch90 on 9th Feb 2015 9:04pm. Edited 1 time in total |
9th Feb 2015 9:01pm |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2875 |
I had this on my td5 needed a new oil pump
9th Feb 2015 9:02pm |
DRW58 Member Since: 23 Feb 2013 Location: Perthshire Posts: 167 |
Hi munch, it flickers on and off at all engine speeds it's bloody annoying. I had a look at the earth connections but couldn't see anything wrong.
I'm going to have to put a piece of black tape over the light to retain my sanity it won't solve the problem,but will help me till I can do something constructive about it. I built a garage for my Mini With a place for everything and everthing in its place. Ten years down the line there's a Mini in there somewhere, and all's where it should be!!!! Ho hum |
9th Feb 2015 10:30pm |
So it must be a switch or wiring fault , not oil pressure problem
9th Feb 2015 10:32pm |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 |
Is it worth the risk? Get the oil pressure tested, the go from there. It wasn't me!
10th Feb 2015 2:12am |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 |
Mine did the same appears random I am afraid a new oil pump solved it
10th Feb 2015 9:49pm |
