![]() | Home > Td5 > oil pressure warning light flickering |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
I would first try replacing the oil pressure switch,
And go from there ![]() Wanted, Forward Control Anything considered. |
could pull the wire off the switch
if it stops flickering then its the switch if it keeps flickering then its the wiring when does it flicker on tick over or all the time ? Last edited by munch90 on 9th Feb 2015 9:04pm. Edited 1 time in total |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
I had this on my td5 needed a new oil pump
DRW58 Member Since: 23 Feb 2013 Location: Perthshire Posts: 167 ![]() ![]() ![]() |
Hi munch, it flickers on and off at all engine speeds it's bloody annoying. I had a look at the earth connections but couldn't see anything wrong.
I'm going to have to put a piece of black tape over the light to retain my sanity it won't solve the problem,but will help me till I can do something constructive about it. I built a garage for my Mini With a place for everything and everthing in its place. Ten years down the line there's a Mini in there somewhere, and ![]() |
So it must be a switch or wiring fault , not oil pressure problem
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 ![]() ![]() |
Is it worth the risk? Get the oil pressure tested, the go from there. It wasn't me!
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
Mine did the same appears random I am afraid a new oil pump solved it
