Home > Td5 > oil pressure warning light flickering
DRW58
Scotland 2001 Defender 90 Td5 SW Epsom Green
Hi I'm looking for some advice, my oil pressure warning light is flickering on and off incessantly. I've checked and topped up the oil but it's still the same.
I'm thinking it could be an electrical fault as the rear foglamp warning light was showing a dull glow last week, but I've no idea where to look.
Any help advice would be welcome, as the flickering is driving me to distraction
Thanks DRW I built a garage for my Mini
With a place for everything and everthing in its place.
Ten years down the line there's a Mini in there somewhere, and Censored all's where it should be!!!! Ho hum
Post #397413 9th Feb 2015 8:38pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I would first try replacing the oil pressure switch,
And go from there Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #397425 9th Feb 2015 8:50pm
munch90
could pull the wire off the switch
if it stops flickering then its the switch
if it keeps flickering then its the wiring
when does it flicker on tick over or all the time ?
Post #397432 9th Feb 2015 9:01pm
ibexman
I had this on my td5 needed a new oil pump
Post #397433 9th Feb 2015 9:02pm
DRW58
Hi munch, it flickers on and off at all engine speeds it's bloody annoying. I had a look at the earth connections but couldn't see anything wrong.
I'm going to have to put a piece of black tape over the light to retain my sanity it won't solve the problem,but will help me till I can do something constructive about it. I built a garage for my Mini
Post #397479 9th Feb 2015 10:30pm
munch90
So it must be a switch or wiring fault , not oil pressure problem
Post #397481 9th Feb 2015 10:32pm
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
Is it worth the risk? Get the oil pressure tested, the go from there. It wasn't me!
Post #397533 10th Feb 2015 2:12am
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Mine did the same appears random I am afraid a new oil pump solved it
Post #397757 10th Feb 2015 9:49pm
