Home > Technical > Svx led help
Petey
Svx led help
Hi Guys
Just bought some of the svx rear led's and was after some advice before I install them, my mechanic skills are pretty limited!
Probably a stupid question but where exactly does the relay go? Do I need to remove and replace with the new one or just ad the new one?
Sorry but prefer to ask in case I fu** it up!
Thank you
Pete.
Post #396117 5th Feb 2015 7:01pm
Relay is under the steering wheel, behind the acess flap.
Remove old and fit new.
Post #396118 5th Feb 2015 7:03pm
As Steve has said
Open the flap under the steering column with a coin and then with the ignition on set an indicator going, you'll then be able to feel the flasher relay (top left corner) that you'll be replacing
Post #396122 5th Feb 2015 7:10pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Depends which model Defender you have, on my Td5 it's behind the clock cluster, 4 screws to get at it then just replace it.
Post #396143 5th Feb 2015 7:57pm
Petey
Thanks for your replies!
Just fitted them! Only problem is the indicators flash really quickly, any reason why that is please?
It's a 14 plate if that helps.
Thank you
Pete.
Post #396150 5th Feb 2015 8:01pm
You need an adjustable relay, is it one?
Post #396153 5th Feb 2015 8:07pm
Petey
It says Mobile Center led flasher
Post #396157 5th Feb 2015 8:12pm
Petey
It's 3 pin if that helps.
Post #396160 5th Feb 2015 8:15pm
Not sure it's right then, they should have an adjuster knob on them.
Post #396161 5th Feb 2015 8:15pm
You need to adjust the flash rate you see. Thumbs Up
Post #396162 5th Feb 2015 8:16pm
munch90
You dont need to have a adjustable knob , it just needs to be a electronic flasher unit for leds , which it looks like it is by the picture
the one i have used for years is a three pin with no knob on it with leds
only thing with a 3 pin , the trailer indictor light on the dash wont work
faulty flasher unit or you got it in the wrong hole! , what has the old flasher unit or relay got printed on it
Post #396168 5th Feb 2015 8:23pm
Petey
What would happen if I put the old one back in?
Post #396169 5th Feb 2015 8:23pm
munch90
It will flash fast on the old one
have you changed the right one ? Worth checking
Post #396171 5th Feb 2015 8:26pm
K9F
Won't work that's why they've given you a new one! Get back onto Mobilecentre the RDX relays have been proven to work. Do a search under 'RDX relays.' If you go through life with your head in the sand....all people will see is an ar5e!!
Post #396172 5th Feb 2015 8:27pm
Lambley
Mines got an adjustable knob, in the instructions it said something like make the adjustment around 60 flashes per minute, there's an optimum, then the tow light starts flashing on the dash too. Bolt on bits sell them.
Post #396179 5th Feb 2015 8:38pm
