|  | Home > Technical > Svx led help |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    | Relay is under the steering wheel, behind the acess flap.
 Remove old and fit new. | ||
|  5th Feb 2015 6:03pm |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678    | As Steve has said
 Open the flap under the steering column with a coin and then with the ignition on set an indicator going, you'll then be able to feel the flasher relay (top left corner) that you'll be replacing | ||
|  5th Feb 2015 6:10pm |
| Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435      | Depends which model Defender you have, on my Td5 it's behind the clock cluster, 4 screws to get at it then just replace it. | ||
|  5th Feb 2015 6:57pm |
| Petey Member Since: 07 May 2014 Location: Devon Posts: 24    | Thanks for your replies!
 Just fitted them! Only problem is the indicators flash really quickly, any reason why that is please? It's a 14 plate if that helps. Thank you Pete. | ||
|  5th Feb 2015 7:01pm |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    | You need an adjustable relay, is it one? | ||
|  5th Feb 2015 7:07pm |
| Petey Member Since: 07 May 2014 Location: Devon Posts: 24    | It says Mobile Center led flasher
   Click image to enlarge | ||
|  5th Feb 2015 7:12pm |
| Petey Member Since: 07 May 2014 Location: Devon Posts: 24    | It's 3 pin if that helps. | ||
|  5th Feb 2015 7:15pm |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    | Not sure it's right then, they should have an adjuster knob on them. | ||
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    | You need to adjust the flash rate you see.    | ||
|  5th Feb 2015 7:16pm |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558    | You dont need to have a adjustable knob , it just needs to be a electronic  flasher unit for leds , which it looks like it is by the picture
 the one i have used for years is a three pin with no knob on it with leds only thing with a 3 pin , the trailer indictor light on the dash wont work faulty flasher unit or you got it in the wrong hole! , what has the old flasher unit or relay got printed on it Last edited by munch90 on 5th Feb 2015 7:25pm. Edited 1 time in total | ||
|  5th Feb 2015 7:23pm |
| Petey Member Since: 07 May 2014 Location: Devon Posts: 24    | What would happen if I put the old one back in? | ||
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558    | It will flash fast on the old one
 have you changed the right one ? Worth checking | ||
|  5th Feb 2015 7:26pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Won't work that's why they've given you a new one! Get back onto Mobilecentre the RDX relays have been proven to work. Do a search under 'RDX relays.' If you go through life with your head in the sand....all people will see is an ar5e!!
 Treat every day as if it is your last....one day you will be right!! | ||
|  5th Feb 2015 7:27pm |
| Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435      | Mines got an adjustable knob, in the instructions it said something like make the adjustment around 60 flashes per minute, there's an optimum, then the tow light starts flashing on the dash too. Bolt on bits sell them. | ||
|  5th Feb 2015 7:38pm |
| Posting Rules
