![]() | Home > Technical > Svx led help |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20882 ![]() ![]() |
Relay is under the steering wheel, behind the acess flap.
Remove old and fit new. |
As Steve has said
Open the flap under the steering column with a coin and then with the ignition on set an indicator going, you'll then be able to feel the flasher relay (top left corner) that you'll be replacing |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
Depends which model Defender you have, on my Td5 it's behind the clock cluster, 4 screws to get at it then just replace it.
Petey Member Since: 07 May 2014 Location: Devon Posts: 24 ![]() ![]() |
Thanks for your replies!
Just fitted them! Only problem is the indicators flash really quickly, any reason why that is please? It's a 14 plate if that helps. Thank you Pete. |
You need an adjustable relay, is it one?
It says Mobile Center led flasher
It's 3 pin if that helps.
Not sure it's right then, they should have an adjuster knob on them.
You need to adjust the flash rate you see.
You dont need to have a adjustable knob , it just needs to be a electronic flasher unit for leds , which it looks like it is by the picture
the one i have used for years is a three pin with no knob on it with leds only thing with a 3 pin , the trailer indictor light on the dash wont work faulty flasher unit or you got it in the wrong hole! , what has the old flasher unit or relay got printed on it Last edited by munch90 on 5th Feb 2015 8:25pm. Edited 1 time in total |
What would happen if I put the old one back in?
It will flash fast on the old one
have you changed the right one ? Worth checking |
Won't work that's why they've given you a new one! Get back onto Mobilecentre the RDX relays have been proven to work. Do a search under 'RDX relays.' If you go through life with your head in the sand....all people will see is an ar5e!!
Mines got an adjustable knob, in the instructions it said something like make the adjustment around 60 flashes per minute, there's an optimum, then the tow light starts flashing on the dash too. Bolt on bits sell them.
