![]() | Home > Puma (Tdci) > Battery box - remove wheel chock captive bolt? |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1125 ![]() ![]() ![]() |
Same problem here now. Anyone?
![]() Click image to enlarge thanks Frank |
Depends how it's held in. Is it a double ended bolt screwed into a rivnut in which case try unwinding it with a couple of nuts locked together on the thread. Alternatively a decent angle grinder or disc cutter will make short work of it. Steve.
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
Plus one for the angle grinder
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Has anyone any further insight to this topic? I too am running into an interference with this post as I am installing a dual battery tray and I would rather not use the dremel on it in our communal garage if possible... Roaming around 🇳🇴🇨ðŸ‡
10 points for finding this thread
![]() I left it in as my tray was high enough https://www.kraxlr.de/makingof.html#electrics But I think it should be a quick job with a dremel or a hacksaw blade. |
danke vielmals for the reply
Ive now ruined the threads trying to loosen it with dual-nuts and it didnt budge. Time for the dremel.... Cheers Dave Roaming around 🇳🇴🇨🇠|
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
I think it is a flathead stud electrowelded to the panel. It's cutter time!
while we're in the area, any idea why there is a moulded plastic plate under the seatbox/battery box protecting.... nothing? Roaming around 🇳🇴🇨ðŸ‡
This question has come up before and the best guess is an attempt at sound proofing, as it seems to be missing on base models. Darren
