![]() | Home > Puma (Tdci) > Battery box - remove wheel chock captive bolt? |
| macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1139
Same problem here now. Anyone?
Click image to enlarge thanks Frank |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Depends how it's held in. Is it a double ended bolt screwed into a rivnut in which case try unwinding it with a couple of nuts locked together on the thread. Alternatively a decent angle grinder or disc cutter will make short work of it. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568
Plus one for the angle grinder
| Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 435
Has anyone any further insight to this topic? I too am running into an interference with this post as I am installing a dual battery tray and I would rather not use the dremel on it in our communal garage if possible... Roaming around 🇳🇴🇨ðŸ‡
10 points for finding this thread
I left it in as my tray was high enough https://www.kraxlr.de/makingof.html#electrics But I think it should be a quick job with a dremel or a hacksaw blade. |
danke vielmals for the reply
Ive now ruined the threads trying to loosen it with dual-nuts and it didnt budge. Time for the dremel.... Cheers Dave Roaming around 🇳🇴🇨🇠|
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18058
I think it is a flathead stud electrowelded to the panel. It's cutter time!
while we're in the area, any idea why there is a moulded plastic plate under the seatbox/battery box protecting.... nothing? Roaming around 🇳🇴🇨ðŸ‡
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
This question has come up before and the best guess is an attempt at sound proofing, as it seems to be missing on base models. Darren
| All times are GMT |
