Home > Puma (Tdci) > Battery box - remove wheel chock captive bolt?
David128
Australia 2015 Defender 110 Puma 2.2 CSW Zermatt Silver
Anyone managed to remove tha captive bolt in the battery box used to hold the wheel chock down. It is fouling my fitment of dual batteries.
Thanks
David
Post #33751 5th Jun 2010 6:50am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Same problem here now. Anyone?
thanks
Frank
Post #547422 9th Jul 2016 9:15pm
Happyoldgit
Depends how it's held in. Is it a double ended bolt screwed into a rivnut in which case try unwinding it with a couple of nuts locked together on the thread. Alternatively a decent angle grinder or disc cutter will make short work of it. Steve.
http://forums.lr4x4.com
Post #547438 9th Jul 2016 10:21pm
pannawonica
Australia
Plus one for the angle grinder Thumbs Up Very Happy
Post #547531 10th Jul 2016 1:56pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Has anyone any further insight to this topic? I too am running into an interference with this post as I am installing a dual battery tray and I would rather not use the dremel on it in our communal garage if possible... Roaming around 🇳🇴🇨🇭
Post #910999 6th Jul 2021 3:18pm
macfrank
10 points for finding this thread Thumbs Up
I left it in as my tray was high enough
https://www.kraxlr.de/makingof.html#electrics
But I think it should be a quick job with a dremel or a hacksaw blade.
Post #911005 6th Jul 2021 4:32pm
Angus_Beef
danke vielmals for the reply
Ive now ruined the threads trying to loosen it with dual-nuts and it didnt budge. Time for the dremel....
Dave Roaming around 🇳🇴🇨🇭
Post #911007 6th Jul 2021 4:35pm
macfrank
Laughing Thumbs Up
Post #911010 6th Jul 2021 4:53pm
I think it is a flathead stud electrowelded to the panel. It's cutter time!
Post #911023 6th Jul 2021 5:47pm
Angus_Beef
while we're in the area, any idea why there is a moulded plastic plate under the seatbox/battery box protecting.... nothing? Roaming around 🇳🇴🇨🇭
Post #911026 6th Jul 2021 6:03pm
This question has come up before and the best guess is an attempt at sound proofing, as it seems to be missing on base models. Darren
Post #911065 6th Jul 2021 9:37pm
