Home > Puma (Tdci) > LED interior lights continually glow - why ??
Page 3 of 3 <123
MarkM61
Australia 2015 Defender 110 Puma 2.2 SW Santorini Black
http://sdrv.ms/199QUa1
Black wolf, I just looked a the the puma 2.2 wiring diagrams in the link above, posted in another thread by Daniel.
It shows the door switches switching the alarm unit, which switches the interior lights, so you are 100% correct, it is the off state leakage current of alarm unit output.
Anyway, LEDs will not flatten the battery more than incandescent lights, as leakage is always there regardless of bulb type
Post #394838 1st Feb 2015 4:25pm
Cupboard
The fact that this happens tells you it's the 10AS:
durham wrote:
Just to add to the pot, on my 2014 MY (cheap) replacement LED bulbs glow very slightly when all doors closed and as described by OP, only way to prevent is to switch light fitting to "off". They fade as normal, when door closed, but remain with a faint glow, even when driving.
Any sort of solid state switching will cause this, it's called leakage current or quiescent current, that is current in the off/inactive state.
It really is nothing to worry about in this case.
If you're trying to design something with a really low power consumption then it might be, for instance most voltage regulators will merrily munch a few mA all the time (see the Blue Sea USB sockets for instance) and if your total power budget is only a few mA continuous then you have to be aware of it. When I next have my interior light apart I'll measure it, but I would guess that the drain will be <1mA.
Post #394918 1st Feb 2015 8:29pm
mrandmrsh
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
Was there a definitive "this isn't a problem"? I put my LED interior bulbs in today and noticed the slight glow. As above turning the switch off turns the glow off. It's only a slight flow as it is only dimly lighting up three of the nine LED units.
It's there all the time if the switch is set to come on with the doors. Kinda looks like "mood lighting" when driving along.
My previous 2012 110 didn't do this. Is the 15MY alarm different to the 12/13?
Regards
Craig 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs)
2012 '62' 2.2 X-Tech 110 USW now gone ...
1984 90 soft top with full roll cage, 200 tdi engine etc now sold
2012 USW XS 2.2 "FUU" now gone....
Post #412163 29th Mar 2015 8:43pm
dgardel
Italy
I installed this, three years ago, on the back (in the front I have the roof console also with led) and is still working ...
http://www.ebay.co.uk/itm/LED-PANELS-PIAST...566ae9b109
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #412224 29th Mar 2015 11:44pm
MrConfidence
Germany
Had the same problem... go buy some dimmable LED bulbs with built-in capacitor.
Works well since then.
Post #416636 16th Apr 2015 4:24pm
Morepower
New Zealand
Have you got a link to a supplier?
Thanks Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #465136 20th Oct 2015 10:48pm
MrConfidence
Germany
Post #465165 21st Oct 2015 8:12am
Morepower
New Zealand
Thanks... I have friends in Germany... So I'll get them to sort some for me..
Regards
Post #465258 21st Oct 2015 2:28pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Here are a few pix of what's happening, taken in my truck when I fitted LED interior slabs.....
Pic 1. 12v, interior light fully on
Pic 2. 5v at the time I took the pic, interior light fading down using PWM...
Pic 3. Interior light off, but with about 1.7v flowing.. This is for the alarm to know if the bulb is shagged, and forms part of the alarm trigger circuit..
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #465334 21st Oct 2015 7:50pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Has anyone found LED bulbs that don't cause a glow and still save on the draw of the existing bulb?
Post #508030 25th Feb 2016 2:27pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
Yes, have a read of this http://www.defender2.net/forum/topic42345.html 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #508035 25th Feb 2016 2:33pm
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
Conrad UK supply - http://www.conrad-electronic.co.uk/ce/en/p...tent-1-pcs NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #508097 25th Feb 2016 4:55pm
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
Happens with mine. Even with LEDs fitted by the dealership. Did not at first but do now. Actually quite like it ... a bit like an airliner with the lights dimmed.
Post #508222 25th Feb 2016 9:15pm
Page 3 of 3 <123
