Home > Puma (Tdci) > Steerinlg Lock/Stops |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Does the tyre rub more when at full articulation? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
24th May 2010 5:33pm |
harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309 |
No rubbing yet, previously I could get my clenched fist in the gap, now it's just a finger. Obviously it's not an order of magnitude better, but it is improved it!
24th May 2010 5:43pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
don't go to far or you will load up the tractor joints on full lock 2.4 90 XS
25th May 2010 8:11am |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 280 |
I did the same as you within a week of picking up my 110 1964 Series IIA SWB Truck Cab - gone
1981 Series III SWB Hardtop - gone 1982 Series III SWB Hardtop - gone 1997 300Tdi Defender 90 Hardtop - gone 1983 Series III SWB Station Wagon - gone 1979 Series III SWB Station Wagon - gone 2007 90 CSW - gone 2010 USW XS - gone 2010 110 USW - gone 1959 Series II Truck Cab 1984 Series III CSW 2004 TD5 90 CSW |
25th May 2010 8:34am |
SJM Member Since: 09 Dec 2007 Location: Kent Posts: 237 |
If it's this simple to help improve the turning circle then why don't they come like that from the factory? Am I missing something?
29th May 2010 1:55pm |
Mine was there on one side anyway and quite far off on the other so I was just equalling them up. Guess they're roughly thrown together in the factory.
29th May 2010 4:33pm |
Yes but the dealer should adjust them before delivery. Roel
29th May 2010 5:36pm |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 |
Don't think it causes any problem for normal driving, but if off roading beware getting heavy wheel spin on full lock as it will cause issues with CV's etc Andy
29th May 2010 6:34pm |
2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
30th May 2010 8:24am |
I thought only early S1s had an actual Tracta joint. Surely LR have progressed on to a UJ and not still using 'Tracta' joints in the front? Harvey |
30th May 2010 10:36am |
I'd agree, but then again its a LR dealer! I am sure there is a lot they and the manufacturers should do but don't |
30th May 2010 10:38am |
TBH I am not sure she will ever be subjected to any heavy off-road abuse, maybe some over-lands, but I try and avoid excess spinning unless it is resulting in forward motion. No progress usually means I am just digging in deeper which means even more difficult extraction which each revolution of a wheel Thanks and I will no doubt treat her gently! |
30th May 2010 10:40am |
ok ok but ya can can still up the uj's 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
30th May 2010 12:33pm |
Yes, totally agree. Just panicking about Tracta joints, I thought surely they haven't - but then again it is LR :-/
30th May 2010 1:22pm |
