|  | Home > Puma (Tdci) > Steerinlg Lock/Stops |
| alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513      | Does the tyre rub more when at full articulation? One that started out as a 2.4 TDCi 110 XS
 + New Defender 110 First Edition | ||
|  24th May 2010 4:33pm |
| harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309    | No rubbing yet, previously I could get my clenched fist in the gap, now it's just a finger.  Obviously it's not an order of magnitude better, but it is improved it! | ||
|  24th May 2010 4:43pm |
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266      | don't go to far or you will load up the tractor joints on full lock    2.4 90 XS 1968 1/32 scale Britains 109 Pick up. | ||
|  25th May 2010 7:11am |
| mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286      | I did the same as you within a week of picking up my 110 1964 Series IIA SWB Truck Cab - gone
 1981 Series III SWB Hardtop - gone 1982 Series III SWB Hardtop - gone 1997 300Tdi Defender 90 Hardtop - gone 1983 Series III SWB Station Wagon - gone 1979 Series III SWB Station Wagon - gone 2007 90 CSW - gone 2010 USW XS - gone 2010 110 USW - gone 1959 Series II Truck Cab 1984 Series III CSW 2004 TD5 90 CSW | ||
|  25th May 2010 7:34am |
| SJM Member Since: 09 Dec 2007 Location: Kent Posts: 237    | If it's this simple to help improve the turning circle then why don't they come like that from the factory? Am I missing something?    | ||
|  29th May 2010 12:55pm |
| harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309    | Mine was there on one side anyway and quite far off on the other so I was just equalling them up.  Guess they're roughly thrown together in the factory. | ||
|  29th May 2010 3:33pm |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039      | Yes but the dealer should adjust them before delivery. Roel
 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) | ||
|  29th May 2010 4:36pm |
| CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803    | Don't think it causes any problem for normal driving, but if off roading beware getting heavy wheel spin on full lock as it will cause issues with CV's etc Andy | ||
|  29th May 2010 5:34pm |
|  30th May 2010 7:24am |
 I thought only early S1s had an actual Tracta joint. Surely LR have progressed on to a UJ and not still using 'Tracta' joints in the front? Harvey | ||
|  30th May 2010 9:36am |
 I'd agree, but then again its a LR dealer! I am sure there is a lot they and the manufacturers should do but don't  | ||
|  30th May 2010 9:38am |
 TBH I am not sure she will ever be subjected to any heavy off-road abuse, maybe some over-lands, but I try and avoid excess spinning unless it is resulting in forward motion. No progress usually means I am just digging in deeper which means even more difficult extraction which each revolution of a wheel   Thanks and I will no doubt treat her gently! | ||
|  30th May 2010 9:40am |
 ok ok but ya can can still  up the uj's  2.4 90 XS 1968 1/32 scale Britains 109 Pick up. | ||
|  30th May 2010 11:33am |
| harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309    | Yes, totally agree.  Just panicking about Tracta joints, I thought surely they haven't - but then again it is LR :-/ | ||
|  30th May 2010 12:22pm |
| Posting Rules
