Home > Puma (Tdci) > Steerinlg Lock/Stops
harveyg77
Wound my steering locks in/off by a means of trial and error. Would seem I can now complete manoeuvres with greater ease and less resemblance to an oil tanker! I've wound them in to the extent that my tyre has a fingers gap between itself anything I could find that it was likely to touch Wink
Any problems with this setup? Anything I'v not thought of?
Post #32796 23rd May 2010 8:32am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Does the tyre rub more when at full articulation? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #32857 24th May 2010 5:33pm
harveyg77
No rubbing yet, previously I could get my clenched fist in the gap, now it's just a finger. Obviously it's not an order of magnitude better, but it is improved it!
Post #32859 24th May 2010 5:43pm
Grockle
don't go to far or you will load up the tractor joints on full lock Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #32898 25th May 2010 8:11am
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
I did the same as you within a week of picking up my 110 1964 Series IIA SWB Truck Cab - gone
1981 Series III SWB Hardtop - gone
1982 Series III SWB Hardtop - gone
1997 300Tdi Defender 90 Hardtop - gone
1983 Series III SWB Station Wagon - gone
1979 Series III SWB Station Wagon - gone
2007 90 CSW - gone
2010 USW XS - gone
2010 110 USW - gone
1959 Series II Truck Cab
1984 Series III CSW
2004 TD5 90 CSW
Post #32900 25th May 2010 8:34am
SJM
If it's this simple to help improve the turning circle then why don't they come like that from the factory? Am I missing something? Confused
Post #33213 29th May 2010 1:55pm
harveyg77
Mine was there on one side anyway and quite far off on the other so I was just equalling them up. Guess they're roughly thrown together in the factory.
Post #33222 29th May 2010 4:33pm
roel
Yes but the dealer should adjust them before delivery. Roel
2003 90 Td5 (2009-now)
Post #33223 29th May 2010 5:36pm
CFB
Don't think it causes any problem for normal driving, but if off roading beware getting heavy wheel spin on full lock as it will cause issues with CV's etc Andy
Post #33228 29th May 2010 6:34pm
Grockle
Whistle 2.4 90 XS
Post #33248 30th May 2010 8:24am
harveyg77
I thought only early S1s had an actual Tracta joint. Surely LR have progressed on to a UJ and not still using 'Tracta' joints in the front?
Harvey
Post #33267 30th May 2010 10:36am
harveyg77
I'd agree, but then again its a LR dealer! I am sure there is a lot they and the manufacturers should do but don't Wink
Post #33268 30th May 2010 10:38am
harveyg77
TBH I am not sure she will ever be subjected to any heavy off-road abuse, maybe some over-lands, but I try and avoid excess spinning unless it is resulting in forward motion. No progress usually means I am just digging in deeper which means even more difficult extraction which each revolution of a wheel Sad
Thanks and I will no doubt treat her gently!
Post #33269 30th May 2010 10:40am
Grockle
Grockle wrote:
Whistle
ok ok but ya can can still Censored up the uj's Thumbs Up 2.4 90 XS
Post #33279 30th May 2010 12:33pm
harveyg77
Yes, totally agree. Just panicking about Tracta joints, I thought surely they haven't - but then again it is LR :-/
Post #33280 30th May 2010 1:22pm
