![]() | Home > Maintenance & Modifications > how to fit a roof lining |
Shutts Member Since: 10 Aug 2014 Location: Tiptree Posts: 52 ![]() ![]() ![]() |
Guys
Just managed to lay my hands on a new roof lining for a 90. Does anyone have a guide on how to fit it, and what additional items I would need to fit it to a hard top. Shutts |____000_ [l_|__\___\,___ l--___--_[O==O] ()_)' '()_)-----()_) 2005 D3 SE 1998 Disco 300tdi - slow play thing 1995 Defender 300tdi - Winching play thing Aprilia RSV 1000 - fast play thing Honda CR250 - noisy play thing Essex Land Rover Club member ------- Andy's Landy's - http://www.andys-landys.blogspot.com Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip |
Knot-yet Member Since: 21 Nov 2013 Location: N. Lincs Posts: 39 ![]() ![]() |
I recently fitted the missing rear section of headlining to my base spec hard top.
And found the LRM defender 110 headlining articles on following webpage useful as a general guide before tackling the job. http://www.lasalle-trim.co.uk/media Hope this helps |
Knot-yet
Many thanks for the links, they will be very useful when fitting the new linings. Do you know if I need any more brackets, also the number of fir trees clips required. Shutts |____000_ [l_|__\___\,___ l--___--_[O==O] ()_)' '()_)-----()_) 2005 D3 SE 1998 Disco 300tdi - slow play thing 1995 Defender 300tdi - Winching play thing Aprilia RSV 1000 - fast play thing Honda CR250 - noisy play thing Essex Land Rover Club member ------- Andy's Landy's - http://www.andys-landys.blogspot.com Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip |
TD5 SMUT Member Since: 12 Feb 2014 Location: Worcestershire Posts: 23 ![]() ![]() ![]() |
Just done the same to mine but a dc is a bit of a pig!!!
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Last edited by TD5 SMUT on 20th Nov 2014 12:33am. Edited 3 times in total |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
A great idea from someone on here(sorry, can't remember who) is to use a camera tripod to hold the lining in position whilst you do the final fixings.
Fair play, thats a great idea.
MarkyMark Member Since: 28 Oct 2014 Location: New Forest Hampshire Posts: 62 ![]() ![]() ![]() |
I really like the dark roof lining
Yes i am really impressed, i have sound proofed the whole cab too i will post a load more images later,
i know of the same liner for a 90 at the right money!! pm me |
TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286 ![]() ![]() ![]() |
Knot-yet, When you fitted the rear lining to your hard top what did you do about fitting the rear piece that goes over the door? On a SW there are metal brackets spot welded to the roof to push the fir tree clips into, obviously these are omitted on the HT roof. At the moment the rear over-door piece on mine is just held in by the two grab handles and I pushed the fir trees into the section just to hide the holes. Tom @tditomprice 100” Defender Hybrid 2010 Alaska White 90 HT |
Dont know sorry!! maybe rivet a piece in?
I'm still scratching my head over that one. The best I can come up with so far is to make up the necessary bracket from a piece of aluminium and bond it with something like sikaflex adhesive.
At the moment the bit over the door is not fitted. |
epictrail Member Since: 21 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
When i did this I made 2 brackets up and riveted them in place. Also I used Sikkaflex to set the sockets for the 2 grab handles in place.
Guys
After about a year I managed to get the time to cut in the alpine roof lights and fit the roof . Interestingly only 2 out of 6 holes lined up so I will need to drill the other holes. However, one thing I found is that the fir trees don't seem long enough to hold. Can anyone tell me if there are longer ones to go through both roof liners? Andy |____000_ [l_|__\___\,___ l--___--_[O==O] ()_)' '()_)-----()_) 2005 D3 SE 1998 Disco 300tdi - slow play thing 1995 Defender 300tdi - Winching play thing Aprilia RSV 1000 - fast play thing Honda CR250 - noisy play thing Essex Land Rover Club member ------- Andy's Landy's - http://www.andys-landys.blogspot.com Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip |
