![]() | Home > Puma (Tdci) > Wanted one of these |
I know it's a US sourced item but they may ship to the UK??? Have a look here...
One of these... http://www.carpartscheaply.com/store/car-e...pters.html Plus this... http://www.carpartscheaply.com/store/car-e...mount.html And you're well sorted.. just need to figure out if it's compatable and how to fit??? ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 5th May 2010 12:29am. Edited 1 time in total |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
Thanks but not sure how I'll fix a square section extender to my flange tow ball plate?
Was the pictured item sold as a Defender item? If you go through life with your head in the sand....all people will see is an ar5e!!
Personally I can't see how what was pictured would fit... But in answer to your question, possibly with one of these... http://www.carpartscheaply.com/store/car-e...tches.html Whole lot only comes to $163 if it can be supplied for a Defender. If not may give you a couple of ideas if you're 'Engineer Minded?' Shame the seller won't answer your query. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
hi,
I have a pendle bike rack, have a look at http://www.pendle-bike.co.uk/index.php there are lots of options on there, I feel its best to avoid the spare wheel type unless you have a mantec spare wheel carrier. cheers bpman |
No not specifically as a defender item but it has the bolt holes for the flange style tow bar bolts so would fit any tow bar with flange style tow ball |
I already have a tow-bar with standard flange tow ball installed on my Defender. I just want to change the tow ball bit. The part pictured would fit as a direct replacement for a standard flange tow ball. I don't really want to replace the entire tow bar if I can help it. ![]() Click image to enlarge |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 ![]() ![]() ![]() |
Seller won't reply to question as to where he got it
![]() thats a discovery 2 swan neck tow ball ANR6443 look here on page 21 - http://www.discovery2.co.uk/downloads/discovery2_acc.pdf |
Thanks nicks - you are the daddy, that's awesome
Now to track down someone willing to sell the tow ball bit separately Last edited by kmac on 5th May 2010 9:01am. Edited 1 time in total |
i'll fire up the lap top and see if there is a part number for it seperatly on microcat
it'll take 10 mins for it to load up, its getting old. I can't get microcat to work on this pc as its 64bit vista |
Try the parts Manager at Yeoville Land Rover (Nick) he always comes up trumps for me
Hey nicks any joy on microcat?
Any other ideas how to get the twoball an extra 10cm away from the car so the bike rack clears the spare wheel?
Can't seem to find anywhere that will sell the extended towball on its own. |
blue meanie Member Since: 30 Jun 2007 Location: Newbury (ish) Posts: 43 ![]() |
what about a tow bar extension box type thing as fitted to the 130's ? RLD would probably be able to make you something up?
