Home > Puma (Tdci) > Wanted one of these
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Wanted one of these
Need to get a bike carrier on (without buying a new one)
Sits on the tow ball.
To clear rear spare on a Defender, I need on of these but can't find one anywhere
Got the pic form a completed ebay auction
Seller won't reply to question as to where he got it
Post #31458 4th May 2010 11:41pm
K9F
I know it's a US sourced item but they may ship to the UK??? Have a look here...
One of these...
http://www.carpartscheaply.com/store/car-e...pters.html
Plus this...
http://www.carpartscheaply.com/store/car-e...mount.html
And you're well sorted.. just need to figure out if it's compatable and how to fit??? Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #31459 5th May 2010 12:19am
kmac
Thanks but not sure how I'll fix a square section extender to my flange tow ball plate?
Post #31460 5th May 2010 12:22am
K9F
Was the pictured item sold as a Defender item? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #31461 5th May 2010 12:30am
K9F
Personally I can't see how what was pictured would fit... But in answer to your question, possibly with one of these...
http://www.carpartscheaply.com/store/car-e...tches.html
Whole lot only comes to $163 if it can be supplied for a Defender. If not may give you a couple of ideas if you're 'Engineer Minded?'
Shame the seller won't answer your query. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #31462 5th May 2010 12:35am
hi,
I have a pendle bike rack, have a look at http://www.pendle-bike.co.uk/index.php
there are lots of options on there, I feel its best to avoid the spare wheel type unless you have a mantec spare wheel carrier.
cheers
Post #31464 5th May 2010 6:40am
kmac
No not specifically as a defender item but it has the bolt holes for the flange style tow bar bolts so would fit any tow bar with flange style tow ball
Post #31469 5th May 2010 7:43am
kmac
I already have a tow-bar with standard flange tow ball installed on my Defender. I just want to change the tow ball bit. The part pictured would fit as a direct replacement for a standard flange tow ball. I don't really want to replace the entire tow bar if I can help it.
Post #31470 5th May 2010 7:45am
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
Re: Wanted one of these
[/quote]
thats a discovery 2 swan neck tow ball ANR6443
look here on page 21 -
http://www.discovery2.co.uk/downloads/discovery2_acc.pdf
Post #31471 5th May 2010 7:50am
kmac
Thanks nicks - you are the daddy, that's awesome
Now to track down someone willing to sell the tow ball bit separately
Post #31473 5th May 2010 7:57am
nicks
i'll fire up the lap top and see if there is a part number for it seperatly on microcat
it'll take 10 mins for it to load up, its getting old. I can't get microcat to work on this pc as its 64bit vista
Post #31474 5th May 2010 7:59am
Try the parts Manager at Yeoville Land Rover (Nick) he always comes up trumps for me
Post #31482 5th May 2010 9:34am
kmac
Hey nicks any joy on microcat?
Post #31494 5th May 2010 11:57am
kmac
Any other ideas how to get the twoball an extra 10cm away from the car so the bike rack clears the spare wheel?
Can't seem to find anywhere that will sell the extended towball on its own.
Post #31506 5th May 2010 2:42pm
blue meanie
what about a tow bar extension box type thing as fitted to the 130's ? RLD would probably be able to make you something up?
Post #31510 5th May 2010 5:02pm
