Home > Puma (Tdci) > Wanted one of these
Page 2 of 2 <12
kmac
Thanks BM, will PM RLD
Post #31513 5th May 2010 5:32pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
kmac wrote:
Hey nicks any joy on microcat?
no, just checked it not listed as a seperate part.
Post #31606 6th May 2010 3:10pm
kmac
Just an update, that nice chap RLD made one up for me - yipee.
Now just need to locate a hex head, flange face M16 set screw or bolt with fine thread, grade 8.8 , high tensile steel with zinc plating and nyloc nut to match. Not as easy as you might think
Post #32392 17th May 2010 5:11pm
RLD
if you canot get them i will get them for you but try first Whistle RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #32409 17th May 2010 8:37pm
kmac
Post #32417 17th May 2010 9:13pm
RLD
No to long and no nylock nuts will get you some and send them to you tomorow RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #32424 17th May 2010 9:39pm
kmac
Thumbs Up
Post #32431 17th May 2010 10:15pm
Guitarplayer
Sweden 2007 Defender 110 Puma 2.4 XS CSW Java Black
I found this adapter at Monoflex in Sweden, it moves the ball 160mm rearwards.
http://www.monoflex.nu/index.php?page=shop...;lang_id=0
 Land Rover Defender 110 SX Station Wagon 2007
Post #32438 18th May 2010 7:48am
kmac
Thats cool guitar player, the one RLD made for me is like that except it has two bolts instead of four
Have you ordered this?
Had a look around the site, mines like this one
Post #32455 18th May 2010 1:34pm
Guitarplayer
No, I found it when i was looking for a lowering plate to my hitch so that i can get my caravan in level.
If you look close at the picture you can se that it has a reinforcement triangle at the top, thats why it has 4 bolts at the car side. Land Rover Defender 110 SX Station Wagon 2007
Post #32459 18th May 2010 2:27pm
kmac
Yes saw the triangle, probably needed as it is 17cm long.
Mines closer to the shorter one hence only two bolts
Post #32462 18th May 2010 3:56pm
Page 2 of 2 <12
