![]() | Home > Puma (Tdci) > Wanted one of these |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
Thanks BM, will PM RLD
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 ![]() ![]() ![]() |
no, just checked it not listed as a seperate part. |
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 ![]() ![]() |
if you canot get them i will get them for you but try first
Would these do the job?
http://www.halfords.com/webapp/wcs/stores/...yId_165734 |
No to long and no nylock nuts will get you some and send them to you tomorow RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Guitarplayer Member Since: 09 Nov 2009 Location: Akersberga Posts: 18 ![]() ![]() ![]() |
I found this adapter at Monoflex in Sweden, it moves the ball 160mm rearwards.
http://www.monoflex.nu/index.php?page=shop...;lang_id=0 ![]() ![]() |
Thats cool guitar player, the one RLD made for me is like that except it has two bolts instead of four
Have you ordered this? Had a look around the site, mines like this one ![]() |
No, I found it when i was looking for a lowering plate to my hitch so that i can get my caravan in level.
If you look close at the picture you can se that it has a reinforcement triangle at the top, thats why it has 4 bolts at the car side. Land Rover Defender 110 SX Station Wagon 2007 |
Yes saw the triangle, probably needed as it is 17cm long.
Mines closer to the shorter one hence only two bolts |
