![]() | Home > My Defender > 130 DCHCPU conversion to 5 door its started |
| CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803
Loving the paint job Andrew
That's one seriously big Defender!! Andy |
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711
This is the water bladder that sits inside the tank, the rough position of the tank is outlined in red. The bladder was tailor made to suit the dims of the tank and the material the bladder is made from is Potable Water Approved. Click image to enlarge 130's have feeling's as well you know |
| discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200
Very nice mate
| Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216
[s]Sonic[/s] AndrewS why you choose to use a bladder instead of a rigid tank made of plastic or inox? Matteo
Defender 110 Td4 SE MY 09 Last edited by Bomber82 on 6th Sep 2010 6:32am. Edited 1 time in total |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
Think you'll find Its Andrew who has a bladder
Ops....
Defender 110 Td4 SE MY 09 |
Sonic The plastic 'hard' tanks are not available in the size or shape I required. Above the wheel arch on a HiCap Pick up is not as wide as a standard arch in the little Defenders |
Sorry for mistake, we know that you're more talented!!
How the bladder works? has a breather or is sealed, compressing while going empty? Matteo Defender 110 Td4 SE MY 09 |
The bladder is fixed at the top using the eyelets 5 each side and it hangs inside the tank structure. The bladder is slightly larger than the tank structure.
Tha bladder has a 50mm Ø fill a 25mm Ø breather and a 25mm Ø outlet at the base. 130's have feeling's as well you know |
| double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573
andrew's is it possable to commishion a blader with one off dims, i'm thinking about a wedge shaped box behind my second row of seats using that dead space with a high fill hose at one side of the vehical and a low tap hose on the other side ? if so ideas on will it work and a rough cost,
cheers mark |
Mark
The bladders are made bespoke to peoples requirements. Do a sketch with your requirements along with the size of the connections you require and I will price it up for you |
| All times are GMT |
