Home > Puma (Tdci) > fuel tank 2.2tdci
johnbain
fuel tank 2.2tdci
has anyone had any probs with there fuel tank leaking just filled mine up and its dumped about a gallon back on the fore court then its stopped never had this seems to of come from the top of the tank but the return pipe seems fine . Range rover td6
defender2 xtech
Post #352563 19th Aug 2014 6:49pm
leeds
A little fuel will go a long way when it spills on the floor.
Did you fill the tank right up to the filler neck?
Sounds like you might have just lost the contents of the fuel filler pipe.
If so check the hose to tank jubilee clip is done up tight.
Brendan
Post #352567 19th Aug 2014 6:58pm
keith
Home > Pictures & Video > Got here with a fuel leak
Post #352568 19th Aug 2014 7:01pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Just had the breather on mine replaced under warranty as it was cracked where it connects to the tank, lost a couple of gallons all over the forecourt!!! 2014 110 2.2TDCi XS Station wagon - GONE
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - GONE
2024 110 D250 X-Dynamic HSE
Post #352583 19th Aug 2014 7:50pm
90XS
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Corris Grey
Mines the same, can't fill it up properly otherwise it has a little wee all over the forecourt, much to my embarrassment! It's on my list of warranty jobs when it goes in for it's first service!
Post #352585 19th Aug 2014 7:54pm
X4SKP
Hi Johnbain,
If on filling, it leaks then stops, it could well be either the main filler pipe or (in my experience) the breather pipe,
My fix is here...
http://www.defender2.net/forum/topic25866.html SKIP
Post #352620 19th Aug 2014 10:45pm
limbrickh
New Zealand 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
Yes, I have this problem on a 2012 2.2 110.
If I fill it using the automatic cutoff of the bowser it will leak on the forecourt then as I drive along, diesel leaks onto the road and little droplets spray back over the rear door. I think the top 5 litres of the tank leaks.
I have had this repaired once under warranty a year ago and will be getting it done again next month.
To avoid the problem i don't fill the tank to the top. It means I don't get a full range and dirt attaches to the rear chassis because of the wet diesel. It is pretty annoying - if not dangerous.
Post #352627 19th Aug 2014 11:24pm
johnbain
Thanks for response guys its going back under warranty☺ Range rover td6
defender2 xtech
Post #352637 20th Aug 2014 5:51am
