![]() | Home > Puma (Tdci) > fuel tank 2.2tdci |
A little fuel will go a long way when it spills on the floor.
Did you fill the tank right up to the filler neck? Sounds like you might have just lost the contents of the fuel filler pipe. If so check the hose to tank jubilee clip is done up tight. Brendan |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2253 ![]() ![]() |
Home > Pictures & Video > Got here with a fuel leak
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Just had the breather on mine replaced under warranty as it was cracked where it connects to the tank, lost a couple of gallons all over the forecourt!!! 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
90XS Member Since: 01 Aug 2014 Location: Shropshire Posts: 76 ![]() ![]() ![]() |
Mines the same, can't fill it up properly otherwise it has a little wee all over the forecourt, much to my embarrassment! It's on my list of warranty jobs when it goes in for it's first service!
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hi Johnbain,
If on filling, it leaks then stops, it could well be either the main filler pipe or (in my experience) the breather pipe, My fix is here... http://www.defender2.net/forum/topic25866.html SKIP https://www.defender2.net/forum/topic83242.html |
limbrickh Member Since: 05 Oct 2012 Location: Canterbury Posts: 20 ![]() ![]() ![]() |
Yes, I have this problem on a 2012 2.2 110.
If I fill it using the automatic cutoff of the bowser it will leak on the forecourt then as I drive along, diesel leaks onto the road and little droplets spray back over the rear door. I think the top 5 litres of the tank leaks. I have had this repaired once under warranty a year ago and will be getting it done again next month. To avoid the problem i don't fill the tank to the top. It means I don't get a full range and dirt attaches to the rear chassis because of the wet diesel. It is pretty annoying - if not dangerous. |
johnbain Member Since: 28 Oct 2012 Location: livingston Posts: 34 ![]() ![]() |
Thanks for response guys its going back under warranty☺ Range rover td6
defender2 xtech |
