Home > Technical > Converting from TD5 shimmed to standard wheel bearings
excossack
Following on from the issue I had with the rear flange bolts shearing off.
To bring the info into one topic, the parts I think I need are;
A set of TDi wheel bearings
http://shop.defenderbits.co.uk/hub-bearing...2373-p.asp
Thrust washer
Lock nut x 2
tab washer (the one you bend over) to stop the nut undoing
anything else? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #346564 20th Jul 2014 7:47pm
JWL
If you want to go the whole hog.........rear hub seal, paper hub flange gasket and perhaps new hub cap. That's about all, the only other things in there are the circlip and perhaps some shims for the end of the half shaft.
Post #346587 20th Jul 2014 8:59pm
excossack
Thanks John.
Shims for the end of the half shaft? 1999 Defender TD5 110
Regards
John M0VAZ
Post #346590 20th Jul 2014 9:01pm
JWL
I have an odd one on different wheels on mine, they are fitted between the circlip and the hub flange, their purpose totally eludes me but I put them back on as they give a little bit of support to the circlip.
Post #346591 20th Jul 2014 9:08pm
excossack
Ahhh right. Ok, so I guess most of the bits apply to the front as well? 1999 Defender TD5 110
Regards
John M0VAZ
Post #346592 20th Jul 2014 9:10pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
I did this recently as I had a full bearing set for my old 300Tdi 90, but used them on me TD5 110.
Just removed all the TD5 kit and used the new bearings (though the same as the TD5 ones) with the thrust washers and tab washers.
Can re-use the old bearings if in good nick, just remove the centre spacer thing and sit the race back in. But may as well run the new bearings!
Post #346602 20th Jul 2014 9:30pm
JWL
You're fine John, bearing kits the same on all four corners.
Post #346603 20th Jul 2014 9:32pm
