![]() | Home > Technical > Converting from TD5 shimmed to standard wheel bearings |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6035 ![]() ![]() ![]() |
Following on from the issue I had with the rear flange bolts shearing off.
To bring the info into one topic, the parts I think I need are; A set of TDi wheel bearings http://shop.defenderbits.co.uk/hub-bearing...2373-p.asp Thrust washer Lock nut x 2 tab washer (the one you bend over) to stop the nut undoing anything else? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
If you want to go the whole hog.........rear hub seal, paper hub flange gasket and perhaps new hub cap. That's about all, the only other things in there are the circlip and perhaps some shims for the end of the half shaft.
I have an odd one on different wheels on mine, they are fitted between the circlip and the hub flange, their purpose totally eludes me but I put them back on as they give a little bit of support to the circlip.
Ahhh right. Ok, so I guess most of the bits apply to the front as well? 1999 Defender TD5 110
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 ![]() ![]() ![]() |
I did this recently as I had a full bearing set for my old 300Tdi 90, but used them on me TD5 110.
Just removed all the TD5 kit and used the new bearings (though the same as the TD5 ones) with the thrust washers and tab washers. Can re-use the old bearings if in good nick, just remove the centre spacer thing and sit the race back in. But may as well run the new bearings! |
You're fine John, bearing kits the same on all four corners.
