Home > Puma (Tdci) > Bonnet problem
Pim
South Africa
Bonnet problem
The bonnet of our 110 will not open anymore. When you pull the lever you hear some sound from the lock in the front but no movement. Any suggestions?
Pim Series II 1960
101FC Ambulance 1977
130 1996
110 2013
90 pick up 2013
Post #338241 15th Jun 2014 2:14pm
zs1sam
South Africa 2011 Defender 110 Puma 2.4 SW Alpine White
Pim
Suggest you get someone to try and lift the bonnet while you pull the lever. I had similar problem after travelling many km in very dusty area (Richtersveld). Once open, a good spray with WD 40 should sort it out.
Sam
Post #338247 15th Jun 2014 2:54pm
K9F
If you have no joy try dropping a 'pm' to Bob.....
http://www.defender2.net/forum/topic16541.html?highlight=bonnet If you go through life with your head in the sand....all people will see is an ar5e!!
Post #338254 15th Jun 2014 4:11pm
Pickles
If you have someone push the bonnet DOWN while you pull the lever, that may release the lock,...understand you've probably already tried that though.
Pickles.
Post #338374 15th Jun 2014 11:28pm
ericvv
Since the truck is still in its factory warranty period, let the dealer sort it out, as if you start tinkering yourself you might get blamed for it. Would be interesting though to hear explanation of what the cause of the problem really was as this bonnet issue seems not a standalone situation. As already said in separate post, my bonnet cable don't work anymore either, dealer failed at a quick fix, and truck is booked in there for 24-06, luckily extended warranty also cover this. Will post later details I find out from dealer.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #338385 16th Jun 2014 5:55am
