![]() | Home > Puma (Tdci) > Bonnet problem |
| Pim Member Since: 13 Jul 2013 Location: Hluhluwe Posts: 23
The bonnet of our 110 will not open anymore. When you pull the lever you hear some sound from the lock in the front but no movement. Any suggestions?
Pim Series II 1960 101FC Ambulance 1977 130 1996 110 2013 90 pick up 2013 |
| zs1sam Member Since: 21 Jun 2013 Location: Cape Town Posts: 30
Pim
Suggest you get someone to try and lift the bonnet while you pull the lever. I had similar problem after travelling many km in very dusty area (Richtersveld). Once open, a good spray with WD 40 should sort it out. Cheers Sam |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
If you have no joy try dropping a 'pm' to Bob.....
http://www.defender2.net/forum/topic16541.html?highlight=bonnet If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Since the truck is still in its factory warranty period, let the dealer sort it out, as if you start tinkering yourself you might get blamed for it. Would be interesting though to hear explanation of what the cause of the problem really was as this bonnet issue seems not a standalone situation. As already said in separate post, my bonnet cable don't work anymore either, dealer failed at a quick fix, and truck is booked in there for 24-06, luckily extended warranty also cover this. Will post later details I find out from dealer.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
