Home > Technical > Td5 turns over but won't start sometimes |
Liquid effects Member Since: 14 May 2014 Location: Beckermet Cumbria Posts: 13 |
No problem , thanks for the info , hopefully weev cracked it
15th May 2014 11:32am |
Finally got the injector seals in (finished about 1amthis morning) and a new loom to stop the oil from traveling down the loom , tried to start it and it was rough and didn't want to have a go so I left it for a couple mins and tried again ...started with a splutter and then ticked over perfectly , put some revs on and it sounded fine so I replaced the oil incase it had Desiel in from the leaking injectors and it's been perfect all day , stop and started it about 10 times so am happy . Biggest job I have done on an engine to date . Thanks for everyone's input .
PS incase anyone else reads this and attempts it- didn't have the injector remover tool so I stripped a pair of slip joint pliers down and used the 90 degree side. Worked perfectly. Think you would struggle with out the proper gear otherwise |
16th May 2014 11:32pm |
£85 for seals , copper washers and a injector loom , all genuine landrover
16th May 2014 11:34pm |
I've used a long allen key for extracting the injectors before now, that worked well also.
17th May 2014 12:25am |
Yer there still abut of a fiddle thow especially the back one where you struggle to reach
17th May 2014 12:33am |
17th May 2014 9:49am |
