Home > Technical > Td5 turns over but won't start sometimes
Page 2 of 2 <12
mk1collector
Seals and washers. I've heard they are easy to fit but when I had mine replaced I was having other work done so the garage did it for me so can't really say.
Post #331200 15th May 2014 11:30am
Liquid effects
No problem , thanks for the info , hopefully weev cracked it
Post #331201 15th May 2014 11:32am
Liquid effects
Finally got the injector seals in (finished about 1amthis morning) and a new loom to stop the oil from traveling down the loom , tried to start it and it was rough and didn't want to have a go so I left it for a couple mins and tried again ...started with a splutter and then ticked over perfectly , put some revs on and it sounded fine so I replaced the oil incase it had Desiel in from the leaking injectors and it's been perfect all day , stop and started it about 10 times so am happy . Biggest job I have done on an engine to date . Thanks for everyone's input .
PS incase anyone else reads this and attempts it- didn't have the injector remover tool so I stripped a pair of slip joint pliers down and used the 90 degree side. Worked perfectly. Think you would struggle with out the proper gear otherwise
Post #331479 16th May 2014 11:32pm
Liquid effects
£85 for seals , copper washers and a injector loom , all genuine landrover
Post #331481 16th May 2014 11:34pm
Liquid effects
Post #331482 16th May 2014 11:34pm
JWL
I've used a long allen key for extracting the injectors before now, that worked well also.
Post #331490 17th May 2014 12:25am
Liquid effects
Yer there still abut of a fiddle thow especially the back one where you struggle to reach
Post #331492 17th May 2014 12:33am
mk1collector
Thumbs Up
Post #331519 17th May 2014 9:49am
Page 2 of 2 <12
