Home > My Defender > Water leaks, curing them slowly....
Buz
United Kingdom 1987 Defender 90 200 Tdi HT Barolo Black
OK, think I've cured the leaks through the flaps below the windscreen.
Next ones seem to be where the window meets the bulkhead. There is a foam seal, now I always thought foam wasn't actually a seal but would let water through/soak up water? I've also found a part with the foam is actually missing so think this is the main point of entry.
I assume it will be a big old job to replace the actual seal itself?
If so I may just use some sealant to seal the hole.
The window seal is past its best as well, but thinking of upgrading to heated screen if that needs changing...that should be fun, never messed with windows and seals yet Confused
[/URL][/IMG]
[/URL][IMG]
Post #328903 7th May 2014 9:10am
X4SKP
Hello Buz
Keep going and try to fix them all, it's worth it just to be able to drive around without your wellies on Exclamation
The foam seal between the upper and lower body or between the front window and vent bodywork (on bulkhead)
is as you guessed a major job, I have seen it done on a full respray where the defender was split right down, and
I have heard that it is possible to remove and insert the window seal without this step, but have no first hand experience of this, someone on here may (will) know.
Suggest you do the obvious first, use silicon elsewhere to prove the job is worth it to improve things further.
http://www.defender2.net/forum/topic28375.html SKIP
Post #328905 7th May 2014 9:48am
david mitchell
Ireland 2003 Defender 90 Td5 HT Epsom Green
i used sikaflex 291 over my foam gasket. no more leaks! Very Happy take your time to mask it correctly.
Post #328943 7th May 2014 11:49am
Buz
Thanks chaps
Ive bought some PURAFLEX 40 POLYURETHANE HYBRID BASED SEALANT, which i would assume is the same sort of thing?
I was thinking of cutting some of the foam out, mask either side of the foam and then seal over the foam, smoothing it out for a decent finish?
Also as a temp fix on the screen, mask around the rubber then put the sealant in the cracks, I realise this won't be permanent but until i sort out the screen may help hold back the tide Confused
I know they all leak and you won't stop all of it but the more i can the longer the carpet stays dry Wink
Post #328963 7th May 2014 1:07pm
david mitchell
get hold of land rover monthly, april, may and june have "how to cure leaks". july issue will have the final part
Post #329000 7th May 2014 3:07pm
