![]() | Home > My Defender > Water leaks, curing them slowly.... |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hello Buz
Keep going and try to fix them all, it's worth it just to be able to drive around without your wellies on ![]() The foam seal between the upper and lower body or between the front window and vent bodywork (on bulkhead) is as you guessed a major job, I have seen it done on a full respray where the defender was split right down, and I have heard that it is possible to remove and insert the window seal without this step, but have no first hand experience of this, someone on here may (will) know. Suggest you do the obvious first, use silicon elsewhere to prove the job is worth it to improve things further. ![]() Click image to enlarge http://www.defender2.net/forum/topic28375.html SKIP https://www.defender2.net/forum/topic83242.html |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 419 ![]() ![]() ![]() |
i used sikaflex 291 over my foam gasket. no more leaks!
Buz Member Since: 24 Jan 2014 Location: Forest of Dean Posts: 238 ![]() ![]() ![]() |
Thanks chaps
Ive bought some PURAFLEX 40 POLYURETHANE HYBRID BASED SEALANT, which i would assume is the same sort of thing? I was thinking of cutting some of the foam out, mask either side of the foam and then seal over the foam, smoothing it out for a decent finish? Also as a temp fix on the screen, mask around the rubber then put the sealant in the cracks, I realise this won't be permanent but until i sort out the screen may help hold back the tide ![]() I know they all leak and you won't stop all of it but the more i can the longer the carpet stays dry ![]() |
get hold of land rover monthly, april, may and june have "how to cure leaks". july issue will have the final part
