![]() | Home > Maintenance & Modifications > Can anyone recommend some GOOD number plate adhesive? |
and don't forget to wipe surfaces with thinners to get them super-duper sticky
![]() I forgot to do this once with some new (should have been clean) car trim and after spending a lot of time and money bonding it, it disappeared somewhere along the A12 near Witham ![]() Good luck ![]() But shout it at them in German because life is also terrifying and confusing... |
Be in post tomorrow!
![]() Treat every day as if it is your last....one day you will be right!! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
Mal - Thank-you.
![]() Matt - Don't worry I will, isopropyl alcohol works well once it's evaporated. ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
I allways use this:
http://www.bol.com/nl/p/bison-siliconenkit...0010529643 I glue everything with it and the good thing is you can remove it again too. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 ![]() |
As aircraft components are put together with adhesive tapes - sticking a number plate onto a Defender is no big deal. But make sure the surfaces are correctly prepared (cleaned) including the ambient air temperature being above freezing.
Received the tape from Mal today. (cheers mate)
![]() As you can see below the rubbish before I had where the plate was coming away and only hanging on from the top. ![]() It's only been on for a few months and it was put on in the correct procedure I.e. Clean and dry. ![]() Click image to enlarge ![]() Click image to enlarge Cleaned up everything with some isopropyl alcohol on the 90 and the plate, then added the tape to the plate slightly warmed up. ![]() Click image to enlarge Warmed up the bodywork, plate and adhesive and stuck it on nicely. ![]() Click image to enlarge Job jobbed and should stay put now at least! ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2676 ![]() ![]() |
for future references 3M 4991 VHB
is as good as it gets, its what go pro mounts use... |
3M is good.
If it's got "3M" on it, you know it will stick - I guess they've got the patents 'cos nothing else is as good
ZeroGravitas Member Since: 22 Nov 2013 Location: Oxfordshire Posts: 36 ![]() ![]() ![]() |
I've used the Signam adhesive strips on my front and rear plates. There was a pack in with the plates when I got them, and I bought another pack for a couple of quid from Halfords. (Didn't want to drill the plates or the new bumper!)
No issues as yet, but they've only been on a little while... 110 XS TD5 |
Please be aware that 3M (and other manufacturers) produce double sided tapes with adhesive coatings in differing grades. They will all stick to some degree - but some are very high strength and permanent and some are not - they are formulated to be easy to remove/come off under certain conditions - some can even be re-positioned if you don't get the application right first time (i.e. squinty). The adhesives can also specified to suit a particular surface such as painted steel, anodised aluminium and even plasterboard. For those of you who are unsure about the strength of these tapes - next time you are flying - key components of your aircraft will probably be bonded together using this technology. You can also get a variant with 'Velcro' - should you have a need to remove components (for example in an off-road environment). |
uncas Member Since: 22 Nov 2012 Location: Wentworth near Rotherham Posts: 340 ![]() ![]() |
As I'm forever swapping vehicles I use Velcro on the Caravan and trailer and have never had a problem with the plates coming off.
Uncas |
elyassi Member Since: 17 Mar 2013 Location: Abu Dhabi Posts: 17 ![]() ![]() ![]() |
+1 |
TheWarden Member Since: 25 Feb 2013 Location: Southampton Posts: 179 ![]() ![]() ![]() |
Heavy duty Velcro for me - the really wide stuff. I use front and back so I can reposition the plates when I'm offroading - I move the front plate from the bumper to the roofrack as I've lost them off the front in the past. 2013 Aintree Green 110 Station Wagon SX
