Home > Maintenance & Modifications > Can anyone recommend some GOOD number plate adhesive?
Page 2 of 3 <123>
All details in the PM. Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #306652 9th Feb 2014 8:29pm
ZeDefender
and don't forget to wipe surfaces with thinners to get them super-duper sticky Laughing
I forgot to do this once with some new (should have been clean) car trim and after spending a lot of time and money bonding it, it disappeared somewhere along the A12 near Witham Rolling Eyes (although around there it might have been nicked off the car whilst I was driving it...)
Good luck Thumbs Up Tell someone you love them today because life is short.
Post #306655 9th Feb 2014 8:35pm
K9F
Be in post tomorrow! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #306657 9th Feb 2014 8:37pm
Mal - Thank-you. Thumbs Up
Matt - Don't worry I will, isopropyl alcohol works well once it's evaporated. Thumbs Up I've got some of that in wipes form. Thumbs Up ____\We|Will|Win/___
Post #306670 9th Feb 2014 9:03pm
roel
I allways use this:
http://www.bol.com/nl/p/bison-siliconenkit...0010529643
I glue everything with it and the good thing is you can remove it again too. Roel
2003 90 Td5 (2009-now)
Post #306924 10th Feb 2014 7:51pm
Cuthbert
As aircraft components are put together with adhesive tapes - sticking a number plate onto a Defender is no big deal. But make sure the surfaces are correctly prepared (cleaned) including the ambient air temperature being above freezing.
Post #306963 10th Feb 2014 10:12pm
Received the tape from Mal today. (cheers mate) Thumbs Up
As you can see below the rubbish before I had where the plate was coming away and only hanging on from the top. Rolling Eyes
It's only been on for a few months and it was put on in the correct procedure I.e. Clean and dry.
Cleaned up everything with some isopropyl alcohol on the 90 and the plate, then added the tape to the plate slightly warmed up.
Warmed up the bodywork, plate and adhesive and stuck it on nicely.
Job jobbed and should stay put now at least!
Post #307230 11th Feb 2014 7:30pm
Likeomg
for future references 3M 4991 VHB
is as good as it gets, its what go pro mounts use...
Post #307242 11th Feb 2014 8:10pm
3M is good. Thumbs Up ____\We|Will|Win/___
Post #307245 11th Feb 2014 8:15pm
ZeDefender
If it's got "3M" on it, you know it will stick - I guess they've got the patents 'cos nothing else is as good Thumbs Up Tell someone you love them today because life is short.
Post #307274 11th Feb 2014 9:43pm
ZeroGravitas
United Kingdom 2005 Defender 110 Td5 XS CSW Java Black
I've used the Signam adhesive strips on my front and rear plates. There was a pack in with the plates when I got them, and I bought another pack for a couple of quid from Halfords. (Didn't want to drill the plates or the new bumper!)
No issues as yet, but they've only been on a little while... 110 XS TD5
Post #309331 18th Feb 2014 9:26pm
Cuthbert
Please be aware that 3M (and other manufacturers) produce double sided tapes with adhesive coatings in differing grades. They will all stick to some degree - but some are very high strength and permanent and some are not - they are formulated to be easy to remove/come off under certain conditions - some can even be re-positioned if you don't get the application right first time (i.e. squinty). The adhesives can also specified to suit a particular surface such as painted steel, anodised aluminium and even plasterboard.
For those of you who are unsure about the strength of these tapes - next time you are flying - key components of your aircraft will probably be bonded together using this technology.
You can also get a variant with 'Velcro' - should you have a need to remove components (for example in an off-road environment).
Post #309342 18th Feb 2014 9:49pm
uncas
As I'm forever swapping vehicles I use Velcro on the Caravan and trailer and have never had a problem with the plates coming off.
Uncas
Post #309513 19th Feb 2014 2:31pm
elyassi
United Arab Emirates 2015 Defender 90 Puma 2.2 SW Santorini Black
sweepc wrote:
3m VHB tape but make sure you get it straight first time because the plate is not coming back off in one piece Thumbs Up
+1
Post #319982 29th Mar 2014 11:08am
TheWarden
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Heavy duty Velcro for me - the really wide stuff. I use front and back so I can reposition the plates when I'm offroading - I move the front plate from the bumper to the roofrack as I've lost them off the front in the past. 2013 Aintree Green 110 Station Wagon SX
Post #320000 29th Mar 2014 12:47pm
Page 2 of 3 <123>
