Home > Td5 > Td5 and Dynamat |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2876 |
Has anyone actually performed any before and after noise level tests with Dynamat On decibel meter
15th Dec 2013 4:42pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2626 |
i have a decibel meter and a dynamated 2.4, i could try it against some other cars maybe? never thought to get a reading of mine before i did it
15th Dec 2013 5:15pm |
TR51 Member Since: 17 Apr 2012 Location: Dorset UK Posts: 333 |
I used silentcoat on mine (same principal as dynamat and almost identical construction). The description of where I applied it etc are on my TR51 thread ( http://www.defender2.net/forum/topic12967-15.html ).
Results: Engine on, stationary Reduction : 8db 30mph in 3rd Reduction : 14db 50mph in 5th Reduction : 9db 70mph in 5th Reduction : 5db I didn't do the engine bay, roof or wheel arches so if these rant exposed better results may be forthcoming Hope it helps. |
15th Dec 2013 6:28pm |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 |
When I did the front dynamated then added the wright off road kit dropped nearly 10db if I remember correctly was very crude iPhone app mind.
15th Dec 2013 6:58pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
I am going to next year all organised ready to do a proper test Got a TD5 in at the minute chris for full soundproofing CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
15th Dec 2013 8:23pm |
Sounds good will wait to see results
15th Dec 2013 8:38pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
we did a test on a td5 at work before and after and the results was quite good 11db reduction
that was using Skinz soundproofing from Four 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
15th Dec 2013 9:36pm |
Ken B Member Since: 17 Dec 2013 Location: Essex Posts: 106 |
roughly what does it cost to do a full TD5 90 ? Defender 90 TD5 County - You need only two tools in life: WD-40 and duct tape. If it doesnt move and it should: WD-40. If it moves and shouldnt: duct tape it. |
18th Dec 2013 4:50pm |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
That's impressive, I hope mine will be close to that then when I get around to taking out the interior and starting again. I will do a before and after test for people. Has anyone used the dynamat tape to seal the joints up? 2004 TD5 Defender 90 xs station wagon |
18th Dec 2013 8:03pm |
Macpaul Member Since: 26 Mar 2013 Location: SW Surrey Posts: 439 |
Not sure I agree. I've Noisekillered some of it and Dynamatted other bits over a period of time and driving before and after fitting Dynamat definitely made a difference to the level of noise. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
18th Dec 2013 8:36pm |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
That will be due to the reduction in drumming noise, as well as a slight barrier to other noise.
But it isn't a noise barrier in itself. Other than the fact it is something else to travel through. You need an anti-drumming layer (eg dynamat, silentcoat), followed by a thin layer of closed cell foam, followed by mass loaded vinyl - this is very dense and is a proper sound barrier Last edited by Diablo on 19th Dec 2013 2:01pm. Edited 1 time in total |
18th Dec 2013 10:10pm |
Well I don't know the technicalities.
Just Dynamat less noise makes. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
18th Dec 2013 11:11pm |
18th Dec 2013 11:12pm |
As Diablo says you need a layered approach to stop different kinds and frequencys of noise for the best effect. Basically dynamat stops the car making its own noise (vibrations/drumming) with a slight reduction from other noise due to extra mass but is not in itself a noise barrier, so external noise will still be heard. Without going over the top and not being able to refit trim etc, a coat of dynamat (or similar) and say 6 to 10 mm thick closed cell foam (so it doesn't absorb water) is the best and most cost effective way to make a big difference in noise and as a bonus cuts down on condensation during winter months |
19th Dec 2013 11:01am |
